[Qgis-developer] Map canvas flickers
Salvatore Larosa
lrssvtml at gmail.com
Mon Aug 6 13:19:00 PDT 2012
2012/8/6 Ivan Mincik <ivan.mincik at gmail.com>
> > On Mon, 2012-08-06 at 14:34 +0000, Kuhn Matthias, Vermessung
> > wrote:
> > > I don't think that's the problem.
> > > I'll try to reproduce as soon as I'm back on my machine
> > I have a good news. When building on Debian Wheezy with Gnome
> > 3 and QT
> > 4.8.2 I have no QPainter warnings and no resize crashes.
> > Strange, but
> > maybe a newer QT has fixed something.
> > Thanks for You work Matthias.
> > Do you mean with or without the patch?
> I mean WITH patch (on release-1_8 branch, with little adjusting to fit
> to this version).
> > I am on Debian/weezy (GNOME 3) with QGIS (current master) compiled
> > against QT 4.8.2 and I get QPainter warnings on resize!
> Did You applied patch ?
> > Are you sure you compiled with CMAKE_BUILD_TYPE = Debug?
> I am not sure I really need CMAKE_BUILD_TYPE = Debug, but I am building
> it with debug option set now to be sure.
Sorry, but my test was without patch!
Anyway I did try the patch in current master and the flickering is
disappear, but when run QGIS I get an exception: std::bad_alloc.
can it is avoid?
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120806/c1e5d6d3/attachment.html>
