[Qgis-developer] Map canvas flickers
Ivan Mincik
ivan.mincik at gmail.com
Mon Aug 6 13:29:28 PDT 2012
> Sorry, but my test was without patch!
> Anyway I did try the patch in current master and the flickering is
> disappear, but when run QGIS I get an exception: std::bad_alloc.
> can it is avoid?
It could be some another problem with master. Are You sure it happens
only with the patch? Did You applied correct version (mine version is
for 1.8, Matthias's is for master) ?
Ivan Mincik <ivan.mincik at gmail.com>
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120806/df723685/attachment.pgp>
