[Qgis-developer] Map canvas flickers
Salvatore Larosa
lrssvtml at gmail.com
Mon Aug 6 13:43:21 PDT 2012
2012/8/6 Ivan Mincik <ivan.mincik at gmail.com>
> > Sorry, but my test was without patch!
> > Anyway I did try the patch in current master and the flickering is
> > disappear, but when run QGIS I get an exception: std::bad_alloc.
> > can it is avoid?
> It could be some another problem with master. Are You sure it happens
> only with the patch? Did You applied correct version (mine version is
> for 1.8, Matthias's is for master) ?
Yes, it only occurs with the patch and when I run QGIS by shell!
I applied the patch as in attached, is it correct?
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120806/29b63f38/attachment.html>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120806/29b63f38/attachment.obj>
