[Qgis-developer] Map canvas flickers
Ivan Mincik
ivan.mincik at gmail.com
Mon Aug 6 13:49:23 PDT 2012
On Mon, 2012-08-06 at 22:43 +0200, Salvatore Larosa wrote:
> 2012/8/6 Ivan Mincik <ivan.mincik at gmail.com>
> > Sorry, but my test was without patch!
> > Anyway I did try the patch in current master and the
> flickering is
> > disappear, but when run QGIS I get an exception:
> std::bad_alloc.
> > can it is avoid?
> It could be some another problem with master. Are You sure it
> happens
> only with the patch? Did You applied correct version (mine
> version is
> for 1.8, Matthias's is for master) ?
> Yes, it only occurs with the patch and when I run QGIS by shell!
> I applied the patch as in attached, is it correct?
Seems a good one.
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120806/3133c2e3/attachment.pgp>
