[Qgis-developer] Map canvas flickers
Matthias Kuhn
matthias.kuhn at gmx.ch
Mon Aug 6 23:46:14 PDT 2012
Hi Salvatore,
What do you mean with "run QGIS by shell"? Is there another way you can
run your self-compiled version and it works?
I started working on a git repo, based on 1.8. So far only the patch
adjusted by Ivan for 1.8 is applied.
https://github.com/matthias-kuhn/Quantum-GIS.git release-1_8
(Watch out: it's not on the master branch!)
Matthias
On Mon, 2012-08-06 at 22:43 +0200, Salvatore Larosa wrote:
> 2012/8/6 Ivan Mincik <ivan.mincik at gmail.com>
> > Sorry, but my test was without patch!
> > Anyway I did try the patch in current master and the
> flickering is
> > disappear, but when run QGIS I get an exception:
> std::bad_alloc.
> > can it is avoid?
> It could be some another problem with master. Are You sure it
> happens
> only with the patch? Did You applied correct version (mine
> version is
> for 1.8, Matthias's is for master) ?
> Yes, it only occurs with the patch and when I run QGIS by shell!
> I applied the patch as in attached, is it correct?
> Qgis-developer mailing list
