[Qgis-developer] Map canvas flickers
Salvatore Larosa
lrssvtml at gmail.com
Tue Aug 7 01:19:08 PDT 2012
2012/8/7 Matthias Kuhn <matthias.kuhn at gmx.ch>
> Hi Salvatore,
> What do you mean with "run QGIS by shell"?
I mean, running QGIS by CL interface (shell bash linux).
Also I noticed that the exception does not always occur!
Oddly, if I run QGIS (CLI) by the following command: $ qgis --lang us
(adding option --lang),
everythings works fine, while by typing $ qgis, it raises to the Exception.
> Is there another way you can
> run your self-compiled version and it works?
Yes, by clicking on shortcut icon on my dashboard,
simply because in my shortcut I set the command "qgis --lang us"
> I started working on a git repo, based on 1.8. So far only the patch
> adjusted by Ivan for 1.8 is applied.
> https://github.com/matthias-kuhn/Quantum-GIS.git release-1_8
> (Watch out: it's not on the master branch!)
I was aware of what, but it is very annoying issue and I wanted test it!
All the Best,
-SL
> Matthias
> On Mon, 2012-08-06 at 22:43 +0200, Salvatore Larosa wrote:
> > 2012/8/6 Ivan Mincik <ivan.mincik at gmail.com>
> > > Sorry, but my test was without patch!
> > > Anyway I did try the patch in current master and the
> > flickering is
> > > disappear, but when run QGIS I get an exception:
> > std::bad_alloc.
> > > can it is avoid?
> > It could be some another problem with master. Are You sure it
> > happens
> > only with the patch? Did You applied correct version (mine
> > version is
> > for 1.8, Matthias's is for master) ?
> > Yes, it only occurs with the patch and when I run QGIS by shell!
> > I applied the patch as in attached, is it correct?
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120807/b6c3d9d1/attachment.html>
