[Qgis-developer] rasterlayertest broken since 2012-08-04
Tim Sutton
lists at linfiniti.com
Tue Aug 7 00:07:07 PDT 2012
Hi
On Tue, Aug 7, 2012 at 8:47 AM, Radim Blazek <radim.blazek at gmail.com> wrote:
> On Mon, Aug 6, 2012 at 11:41 PM, Tim Sutton <lists at linfiniti.com> wrote:
>>> I thought that any failures would be caught by Tim's Jenkins server
>>> and I would have received and email.
>> Yes I did too - I may have to register the email address of 'users'
>> committers which would probably be impractical. If you have and
>> android or a iphone, you may want to install the free Jenkins monitor
>> tool and point it to my server.
>> http://www.jenkins-ci.mobi/
> I am not able to get it working, I have filled
> Host: jenkins.linfinity.com
> and let other options defaults, but Test configuration gives:
> Connection test PASSED
> Login test PASSED
> Retrieve views test FAILED
> If I try to connect, it gives "Error while loading data: Internal
> server error - 500"
> Is it working for you? What params do I have to fill in?
Try host jenkins.linfiniti.com (note 'i' at the end)
Regards
Tim
> Radim
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
