[Qgis-developer] Have you already made some diagrams today? :)
Kuhn Matthias, Vermessung
Matthias.Kuhn at Stadt-Uster.ch
Wed Aug 15 09:00:37 PDT 2012
New features!
Testers are still very welcome. It's already in a really good and usable shape :-)
+ Cleanup of diagram tab
* The diagram tab looks really different ( I hope better... )
* As lot of context sensitive showing/hiding and enabling/disabling
* Put options into tabs
+ Some tooltips in the diagram tab
+ Warning if the user tries to display a diagram without having assigned any attribute
+ Code cleanup
* Put diagram gui stuff into an own file (it's still rather big this way)
+ Style => Single symbol, Graduated symbol, Categorized symbol
* The scale method can also be scaled by area / diameter now
* Untested: Does it also work for symbols or only for circles?
+ Transparency for diagrams
+ "Show all" option
* It's hidden in the position tab under "PAL engine settings"
* This is a project-wide option as far as I can see
* If show all is enabled, smaller objects are rendered on top of bigger ones
Have fun and let me know what you think
Matthias Kuhn
> -----Original Message-----
> From: qgis-developer-bounces at lists.osgeo.org
> [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of
> Sent: Friday, August 10, 2012 3:03 PM
> To: qgis-developer at lists.osgeo.org
> Subject: [Qgis-developer] Have you already made some diagrams
> today? :)
> If not, please get my branch and make some. There are a lot
> of improvements and changes (Listed further down this page).
> It's probably not production stable but already works reasonably well.
> And while you're already testing code: Its testing Friday!
> NEW FEATURES:
> + Minimum size for diagrams (As an option, scale any diagram smaller
> + than...)
> * Status: Done
> + Text diagram: Center text better vertically (As an option)
> * Status: Done
> + Make diagrams area accurate! By now the radius instead of
> area is scaled.
> * Done for text diagrams and Pie charts
> + New diagram type: Bar chart
> * Done
> * Feedback needed: Do things like "Fixed size" and
> "Increase size of small diagrams" make sense here? Seems a
> bit uncontrollable to me.
> / Ordering: Draw smaller charts on top of bigger one instead
> of hiding colliding diagrams.
> * Done. (For now: Activate new labelling => Advanced =>
> Engine settings: Enable "Show All")
> * Config option in diagrams to come...
> STILL TODO:
> / Charts are not placed on some polygons
> * Need confirmation that this is really a problem with
> Placment method "Free"
> - New diagram option: Split diagrams. (Pie charts / Bar
> charts e.g. age pyramid)
> * Not yet...
> - Redesign of diagram layer
> * Still crowded, tried to give only options that make sense
> in this context. Probably needs to be split up into some more dialogs.
> - Number in pie segments indicating its value
> * ToDo
> - Legend in map composer
> * ToDo
> Regards and enjoy the weekend,
> Matthias
> Qgis-developer mailing list
