[Qgis-developer] Large raster (ecw) identify very long
haubourg regis.haubourg at eau-adour-garonne.fr
Wed Aug 22 02:40:38 PDT 2012
Hi all,
I'm ready to support developpement now, so let's undig a topic discussed
previously here:
http://hub.qgis.org/issues/4594 http://hub.qgis.org/issues/4594
Identify for very large ecw (from 1 to 100 Go - 1 080 000 * 1 090 000
pixels) is extremely long (more than 1min) and results to memory leak.  Very
often, this only gives a useless RGB info because ecw are orthophotos or
topographic scans.
This is a problem if identify mode queries all layers under mouse clic.
1 - Memory leak can be solved by disabling Gdal cache for ecw says Nathan.*
Do you confirm ? Can you give more details so that I write a contract for
it? *
2 - *I would also like to add a behaviour to handle very long response time,
I would really like to have your feedback on it:*
     - Option 1 : Disable identify for very large raster layers in project
properties when raster is loaded. Keep QGS properties if raster is loaded
when opening a project file. Should we add options to configure that in
general options (" Disable very large raster identify " + "raster size
threshold")
     - Option 2 : Offer a checkbox in identify mode options  that could be
named "disable raster identify"
     - Option 3 : Considering it's a very particular problem for huge ecw
users and let's make a plugin that deactivates identify for big raster.   I
must say I don't vote for here because most french public user I know are
using big ecw, and I think it might be harder and more expensive to do this
from python.. (and adds a python plugin to load, adds a thing more to handle
on enterprise config.. )
*I vote for Option 1*
Thoughts guys?
(And welcome to Victor by the way, congratulations!)
View this message in context: http://osgeo-org.1560.n6.nabble.com/Large-raster-ecw-identify-very-long-tp4996953.html
Sent from the Quantum GIS - Developer mailing list archive at Nabble.com.
