[Qgis-developer] No data value in raster transparency list
Radim Blazek
radim.blazek at gmail.com
Thu Aug 23 08:20:25 PDT 2012
On Wed, Aug 22, 2012 at 5:56 PM, Giovanni Manghi
<giovanni.manghi at faunalia.pt> wrote:
> It isn't the only odd thing/bug with nulls and transparency. For example not
> always nulls are rendered transparent
It was true, it should be fixed now, nodata are always transparent.
> and when you try to add them to the
> transparency list the entry is added as 0 instead.
I have changed the select tool so that nodata are not added to the list.
Radim
> On Aug 22, 2012 4:49 PM, "Radim Blazek" <radim.blazek at gmail.com> wrote:
>> Hi,
>> does anybody know why raster no data value is automatically added to
>> transparency list in properties dialog? It makes no sense IMO. No data
>> values are always rendered as transparent, no need to define them also
>> in transparent list.
>> Radim
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
