[Qgis-developer] No data value in raster transparency list
Marco Hugentobler marco.hugentobler at sourcepole.ch
Wed Aug 22 23:15:01 PDT 2012
Hi Radim
Nodata should be rendered transparent in most cases. But it could also
be possible you want to render it differently. E.g. the interpolation
plugin writes nodata value in case it encounters numerical problems.
Then it is useful to have the nodata values coloured to see where
problems happened. Maybe there are other use cases as well.
Regards,
Marco
Am 22.08.2012 17:49, schrieb Radim Blazek:
> Hi,
> does anybody know why raster no data value is automatically added to
> transparency list in properties dialog? It makes no sense IMO. No data
> values are always rendered as transparent, no need to define them also
> in transparent list.
> Radim
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
