[Qgis-developer] No data value in raster transparency list
Radim Blazek
radim.blazek at gmail.com
Thu Aug 23 04:59:38 PDT 2012
On Thu, Aug 23, 2012 at 8:15 AM, Marco Hugentobler
<marco.hugentobler at sourcepole.ch> wrote:
> Hi Radim
> Nodata should be rendered transparent in most cases. But it could also be
> possible you want to render it differently. E.g. the interpolation plugin
> writes nodata value in case it encounters numerical problems. Then it is
> useful to have the nodata values coloured to see where problems happened.
There are other standard ways to highlight nodata:
- set background color
- set nodata pixels to a different value (r.null) and assign a color to it
If you and other users insist that it should be possible to render
nodata with a color, we have to add support for it in GUI (set color)
and renderers. Currently there is no such support.
Radim
> Maybe there are other use cases as well.
> Regards,
> Marco
> Am 22.08.2012 17:49, schrieb Radim Blazek:
>> Hi,
>> does anybody know why raster no data value is automatically added to
>> transparency list in properties dialog? It makes no sense IMO. No data
>> values are always rendered as transparent, no need to define them also
>> in transparent list.
>> Radim
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Dr. Marco Hugentobler
> Sourcepole - Linux & Open Source Solutions
> Weberstrasse 5, CH-8004 Zürich, Switzerland
> marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
> Technical Advisor QGIS Project Steering Committee
