[Qgis-developer] qgisstyle binary file created in scripts folder and QGIS stalls
Bob and Deb
bobdebm at gmail.com
Thu Aug 23 10:06:38 PDT 2012
I've noticed qgis hanging when you have a debug build. When I go to the
console and click in it, the debug output unfreezes and qgis once again is
responsive. Not sure if this is your problem?
On Thu, Aug 23, 2012 at 4:48 AM, aruntheguy at gmail.com
<aruntheguy at gmail.com>wrote:
> Hello all,
> Pardon me for the noise. I figured out that those two unrelated. I am
> still investigating what makes the system to hang.
> On Thu, Aug 23, 2012 at 5:05 PM, aruntheguy at gmail.com <
> aruntheguy at gmail.com> wrote:
>> Hello,
>> I seem to have a weird problem. I compile the code in my build folder.
>> Then fire gdb ~/bin/qgis It all runs fine until
>> Debug: src/core/qgsproviderregistry.cpp: 462: (providerLibrary) Library
>> name is /home/teco/bin/qgis/lib/qgis/plugins/libwcsprovider.so
>> Debug: src/providers/wcs/qgswcsdataitems.cpp: 294: (dataItem) thePath =
>> Debug: src/core/qgsdataitem.cpp: 190: (populate) mPath = wcs:
>> Debug: src/core/qgsbrowsermodel.cpp: 102: (addRootItems) Add new top
>> level item : WCS
>> name is /home/teco/bin/qgis/lib/qgis/plugins/libwmsprovider.so
>> Debug: src/core/qgsdataitem.cpp: 190: (populate) mPath = wms:
>> level item : WMS
>> Then instead of loading the following,
>> Debug: src/app/qgisapp.cpp: 654: (QgisApp) Tips are disabled
>> Debug: src/core/qgsproviderregistry.cpp: 442: (function) Library name is
>> /home/teco/bin/qgis/lib/qgis/plugins/libwfsprovider.so
>> /home/teco/bin/qgis/lib/qgis/plugins/libdelimitedtextprovider.so
>> /home/teco/bin/qgis/lib/qgis/plugins/libgdalprovider.so
>> /home/teco/bin/qgis/lib/qgis/plugins/libgpxprovider.so
>> QGIS simply just stalls, hard disk keeps spinning and CPU foes to 100%,
>> effectively hanging the entire system. I had to manually power off the
>> computer. I find a binary file "qgisstyle" in the scripts folder of qgis
>> repo source. This only seem to happen after the first run after compile.
>> Anyone could explain what I am being hit by?
>> Regards
>> Arunmozhi
>> Twitter: @tecoholic
>> Website: http://arunmozhi.in
>> IRC Nick: teco
> Regards
> Arunmozhi
> Twitter: @tecoholic
> IRC Nick: teco
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120823/f2fa0686/attachment.html>
