[Qgis-developer] qgisstyle binary file created in scripts folder and QGIS stalls
aruntheguy at gmail.com aruntheguy at gmail.com
Thu Aug 23 04:48:18 PDT 2012
Hello all,
Pardon me for the noise. I figured out that those two unrelated. I am still
investigating what makes the system to hang.
On Thu, Aug 23, 2012 at 5:05 PM, aruntheguy at gmail.com
<aruntheguy at gmail.com>wrote:
> Hello,
> I seem to have a weird problem. I compile the code in my build folder.
> Then fire gdb ~/bin/qgis It all runs fine until
> Debug: src/core/qgsproviderregistry.cpp: 462: (providerLibrary) Library
> name is /home/teco/bin/qgis/lib/qgis/plugins/libwcsprovider.so
> Debug: src/providers/wcs/qgswcsdataitems.cpp: 294: (dataItem) thePath =
> Debug: src/core/qgsdataitem.cpp: 190: (populate) mPath = wcs:
> Debug: src/core/qgsbrowsermodel.cpp: 102: (addRootItems) Add new top level
> item : WCS
> name is /home/teco/bin/qgis/lib/qgis/plugins/libwmsprovider.so
> Debug: src/core/qgsdataitem.cpp: 190: (populate) mPath = wms:
> item : WMS
> Then instead of loading the following,
> Debug: src/app/qgisapp.cpp: 654: (QgisApp) Tips are disabled
> Debug: src/core/qgsproviderregistry.cpp: 442: (function) Library name is
> /home/teco/bin/qgis/lib/qgis/plugins/libwfsprovider.so
> /home/teco/bin/qgis/lib/qgis/plugins/libdelimitedtextprovider.so
> /home/teco/bin/qgis/lib/qgis/plugins/libgdalprovider.so
> /home/teco/bin/qgis/lib/qgis/plugins/libgpxprovider.so
> QGIS simply just stalls, hard disk keeps spinning and CPU foes to 100%,
> effectively hanging the entire system. I had to manually power off the
> computer. I find a binary file "qgisstyle" in the scripts folder of qgis
> repo source. This only seem to happen after the first run after compile.
> Anyone could explain what I am being hit by?
> Regards
> Arunmozhi
> Twitter: @tecoholic
> Website: http://arunmozhi.in
> IRC Nick: teco
Regards
Arunmozhi
Twitter: @tecoholic
IRC Nick: teco
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120823/bf405282/attachment.html>
