[Qgis-developer] qgisstyle binary file created in scripts folder and QGIS stalls
aruntheguy at gmail.com
Thu Aug 23 04:35:14 PDT 2012
Hello,
I seem to have a weird problem. I compile the code in my build folder. Then
fire gdb ~/bin/qgis It all runs fine until
Debug: src/core/qgsproviderregistry.cpp: 462: (providerLibrary) Library
name is /home/teco/bin/qgis/lib/qgis/plugins/libwcsprovider.so
Debug: src/providers/wcs/qgswcsdataitems.cpp: 294: (dataItem) thePath =
Debug: src/core/qgsdataitem.cpp: 190: (populate) mPath = wcs:
Debug: src/core/qgsbrowsermodel.cpp: 102: (addRootItems) Add new top level
item : WCS
name is /home/teco/bin/qgis/lib/qgis/plugins/libwmsprovider.so
Debug: src/core/qgsdataitem.cpp: 190: (populate) mPath = wms:
item : WMS
Then instead of loading the following,
Debug: src/app/qgisapp.cpp: 654: (QgisApp) Tips are disabled
Debug: src/core/qgsproviderregistry.cpp: 442: (function) Library name is
/home/teco/bin/qgis/lib/qgis/plugins/libwfsprovider.so
/home/teco/bin/qgis/lib/qgis/plugins/libdelimitedtextprovider.so
/home/teco/bin/qgis/lib/qgis/plugins/libgdalprovider.so
/home/teco/bin/qgis/lib/qgis/plugins/libgpxprovider.so
QGIS simply just stalls, hard disk keeps spinning and CPU foes to 100%,
effectively hanging the entire system. I had to manually power off the
computer. I find a binary file "qgisstyle" in the scripts folder of qgis
repo source. This only seem to happen after the first run after compile.
Anyone could explain what I am being hit by?
Regards
Arunmozhi
Twitter: @tecoholic
Website: http://arunmozhi.in
IRC Nick: teco
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120823/a31f0d22/attachment-0001.html>
