[Qgis-developer] Symbol transparency, wrong value stored and displayed
Giuseppe Sucameli
brush.tyler at gmail.com
Wed Aug 22 16:16:35 PDT 2012
Hi all,
I noticed that the alpha value stored in the QML for
QgsSimpleFillSymbolLayer objects is wrong.
Here's the QML generated when the symbol transparency is 70%:
<pre>
<symbol outputUnit="MM" alpha="0.298039" type="fill" name="0">
<layer pass="0" class="SimpleFill" locked="0">
<prop k="color" v="255,128,0,76"/>
<prop k="color_border" v="0,0,0,76"/>
</layer>
</symbol>
</pre>
The alpha value for the whole symbol is right (~0.30), instead the
layer's color alpha should be 255, not 76 (which is 0.30*255).
Old style files would be rendered using double transparency after
the fix, unless I convert style files using the
QgsProjectFileTransform::transform1800to1900() function like it's
done for project files, but anyway those ones created using QGis
master (before the fix) will still be affected and I guess this is
not avoidable.
I'm already on it :)
Furthermore, the alpha value of a symbol is not taken into account
while drawing its sub-symbols.
E.g. with a symbol fill (transparency 50%) -> line pattern fill ->
outline (transparency 0%) -> simple line I would suppose the
simple line should be semitransparent because child of the
semi-transparent symbol fill, but it's fully opaque.
Is it the supposed behavior?
Regards.
Giuseppe Sucameli
