[Qgis-developer] Sextante - OTB plugin and SAR data
Noli Sicad
nsicad at gmail.com
Mon Aug 27 03:24:29 PDT 2012
Hi Julien,
Thanks for your reply.
Now, how to use cmake on InsightToolkit-4.2.0?
There is no instruction how to I install ITK (i.e.
InsightToolkit-4.2.0) using cmake?
Anybody how to know how to install ITK?
(I installed cmake already for Mac OS X.)
Thanks,
Noli
On 8/27/12, Julien Malik <julien.malik at c-s.fr> wrote:
> Hi Noli
> Monteverdi is not "OTB for MacOSX".
> Monteverdi is one desktop application with some OTB functionnalities in it.
> This is unrelated to the Qgis/Sextante interface.
> To use OTB from Qgis on MacOSX, you will need to compile OTB from sources.
> Instructions can be found in [1] and [2].
> Especially, you need to set BUILD_APPLICATIONS to ON.
> Regards,
> Julien
> [1]
> http://www.orfeo-toolbox.org/SoftwareGuide/SoftwareGuidech2.html#x14-270002.2
> [2]
> http://www.orfeo-toolbox.org/SoftwareGuide/SoftwareGuidech32.html#x61-43200032.4
> Le 27/08/2012 09:52, Noli Sicad a écrit :
>>>> How do you install this Sextante - OTB plugin?
>>> The first thing you have to do is to install OTB,
>>> then if you are using Sextante on Linux nothing to do anymore.
>>> path to binaries are automatically found and algs should work, while on
>>> Windows you have to configure it.
>>> In "options and configuration" menu, you find what you need!
>> As I mentioned, this is Mac OS X.
>> I installed Monteverdi-1.12 (which is OTB for Mac OS X). It has a
>> Resources/lib/otb and Resources/MacOS folders.
>> /lib/otb folder is where the dynamic libraries is located.
>> /MacOS folder has the other libraries (e.g. libgeos.dylib, etc.).
>> Any suggestion how to organise (e.g copy these libraries)?
>> How to you compile OTB in Linux?
>> http://www.orfeo-toolbox.org/otb/download.html
>> I can compile this in Mac OS X.
>> Note that MacOS X is just like linux system. The system look like this:
>> /usr/local/bin
>> /usr/local/library
>> /usr/loca/include
>> How do you install the QGIS Sextante OTB plugin in Linux?
>> Noli
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
