[Qgis-developer] Sextante - OTB plugin and SAR data
Julien Malik
julien.malik at c-s.fr
Mon Aug 27 01:21:42 PDT 2012
Hi Noli
Monteverdi is not "OTB for MacOSX".
Monteverdi is one desktop application with some OTB functionnalities in it.
This is unrelated to the Qgis/Sextante interface.
To use OTB from Qgis on MacOSX, you will need to compile OTB from sources.
Instructions can be found in [1] and [2].
Especially, you need to set BUILD_APPLICATIONS to ON.
Regards,
Julien
[1]
http://www.orfeo-toolbox.org/SoftwareGuide/SoftwareGuidech2.html#x14-270002.2
[2]
http://www.orfeo-toolbox.org/SoftwareGuide/SoftwareGuidech32.html#x61-43200032.4
Le 27/08/2012 09:52, Noli Sicad a écrit :
>>> How do you install this Sextante - OTB plugin?
>> The first thing you have to do is to install OTB,
>> then if you are using Sextante on Linux nothing to do anymore.
>> path to binaries are automatically found and algs should work, while on
>> Windows you have to configure it.
>> In "options and configuration" menu, you find what you need!
> As I mentioned, this is Mac OS X.
> I installed Monteverdi-1.12 (which is OTB for Mac OS X). It has a
> Resources/lib/otb and Resources/MacOS folders.
> /lib/otb folder is where the dynamic libraries is located.
> /MacOS folder has the other libraries (e.g. libgeos.dylib, etc.).
> Any suggestion how to organise (e.g copy these libraries)?
> How to you compile OTB in Linux?
> http://www.orfeo-toolbox.org/otb/download.html
> I can compile this in Mac OS X.
> Note that MacOS X is just like linux system. The system look like this:
> /usr/local/bin
> /usr/local/library
> /usr/loca/include
> How do you install the QGIS Sextante OTB plugin in Linux?
> Noli
> Qgis-developer mailing list
