[Qgis-developer] Sextante - OTB plugin and SAR data in Mac OS X
William Kyngesburye woklist at kyngchaos.com
Mon Aug 27 19:35:45 PDT 2012
Noli,
I started looking at this to see what needs to be done to use my frameworks.
First, FLTK.
You need the dev 1.3.x source, for updates to support the new libpng in my UnixImageIO framework.  You also need my FreeType framework (not part of the QGIS requirements).
This configuration is just minimal - no tests/examples.  I'm not sure if some of the options are needed for a static build, though may be if you want the examples.  (the build system is messy - checking for things twice, ignoring what I give it, ...)  in a Terminal, in the fltk source folder:
mkdir build-snow
cd build-snow
cmake -Wno-dev -D CMAKE_INSTALL_PREFIX=/usr/local \
-D CMAKE_BUILD_TYPE=MinSizeRel \
-D CMAKE_OSX_ARCHITECTURES="x86_64" \
-D OPTION_BUILD_EXAMPLES=OFF \
-D HAVE_FREETYPE_H=/Library/Frameworks/FreeType.framework/Headers/freetype.h \
-D FREETYPE_PATH=/Library/Frameworks/FreeType.framework/Headers/config \
-D LIB_png=/Library/Frameworks/UnixImageIO.framework \
I'm working on OTB now.  I'll get back to you when I figure that out, probably in a day or two.
On Aug 27, 2012, at 8:57 PM, Noli Sicad wrote:
> Hi Julien,
> As you can see I am not using MacPort. MacPort download the source in
> the script that you mentioned in your previous posting?
> http://www.orfeo-toolbox.org/otb/download.html
> Based on the instruction above. It is not clear what to do with hg
> cloning in Mac OS X.
> Yes, I can do (below) in the terminal.
> hg clone http://hg.orfeo-toolbox.org/OTB
> Would this suffice, or I need to more?
> What do, I do next, do I need to clone OTB-Applications and OTB-Qgis-plugin?
>    OTB-Applications
> The current development version is available from the OTB-Applications
> mercurial repository at: http://hg.orfeo-toolbox.org/OTB-Applications
>    OTB-Qgis-plugins
> The current development version is available from the OTB-Qgis-plugins
> mercurial repository at: http://hg.orfeo-toolbox.org/OTB-Qgis-plugins
> Noli
> Qgis-developer mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole.  Now what does that remind me of?  Ah, yes - life."
- Marvin
