[Qgis-developer] Sextante - OTB plugin and SAR data in Mac OS X
Noli Sicad
nsicad at gmail.com
Tue Aug 28 22:33:18 PDT 2012
Hi Julien,
I tried your script and I got this error (below)
Noli
Last login: Wed Aug 29 15:07:22 on ttys011
Nolis-MacBook-Pro:OTB nsicad$ ctest -S otb.cmake -VV
* Extra verbosity turned on
Reading Script: /Users/nsicad/Documents/Work_1new/OTB/otb.cmake
CMake Error at otb.cmake:100 (ctest_empty_binary_directory):
ctest_empty_binary_directory called with incorrect number of arguments
CMake Error at otb.cmake:104 (ctest_start):
ctest_start binary directory not specified. Specify binary directory as an
argument or set CTEST_BINARY_DIRECTORY
SetCTestConfiguration:SourceDirectory:/Users/nsicad/Documents/Work_1new/OTB/build
SetCTestConfigurationFromCMakeVariable:HGCommand:CTEST_HG_COMMAND
SetCTestConfiguration:HGCommand:/usr/local/bin/hg
SetCTestConfigurationFromCMakeVariable:HGUpdateOptions:CTEST_HG_UPDATE_OPTIONS
SetCTestConfiguration:HGUpdateOptions:-C
SetCTestConfiguration:BuildDirectory:/Users/nsicad/Documents/Work_1new/OTB
Cannot create directory /Testing/Temporary
Cannot create log file: LastUpdate.log
Updating the repository: /Users/nsicad/Documents/Work_1new/OTB/build
Cannot find UpdateCommand configuration key.
CMake Error at otb.cmake:106 (file):
file Internal CMake error when trying to open file: /CMakeCache.txt for
writing.
Cannot instantiate test handler ctest_configure
CMake Error at otb.cmake:107 (ctest_configure):
ctest_configure CMakeLists.txt file does not exist
[/Users/nsicad/Documents/Work_1new/OTB/build/CMakeLists.txt]
CMake Error at otb.cmake:108 (ctest_read_custom_files):
ctest_read_custom_files called with incorrect number of arguments
SetCTestConfiguration:MakeCommand:/usr/bin/make -j8 -i -k
Build project
Cannot create log file: LastBuild.log
Cannot create build log file
Run command: "/usr/bin/make" "-j8" "-i" "-k"
Each symbol represents 1024 bytes of output.
'!' represents an error and '*' a warning.
!make: *** No targets specified and no makefile found. Stop.
Size of output: 0K
Command exited with the value: 2
Current Tag empty, this may mean NightlyStartTime /
CTEST_NIGHTLY_START_TIME was not set correctly. Or maybe you forgot to
call ctest_start() before calling ctest_configure().
Cannot create build XML file
Error in read script: /Users/nsicad/Documents/Work_1new/OTB/otb.cmake
