[Qgis-developer] Sextante - OTB plugin and SAR data in Mac OS X
Julien Malik julien.malik at c-s.fr
Tue Aug 28 01:42:19 PDT 2012
Le 28/08/2012 06:30, Noli Sicad a écrit :
> Hi Julien,
> Disregard my last question, my last posting. I got confuse with the
> "macport" reference in the script.
> I read the script again and I got it now, almost.
> I see I don't need to hg clone manually since it will be pulling the
> nightly build
> execute_process( COMMAND ${CTEST_HG_COMMAND} pull
> http://hg.orfeo-toolbox.org/OTB-Nightly
>                   WORKING_DIRECTORY "${CTEST_SOURCE_DIRECTORY}"
>                   OUTPUT_VARIABLE   PULL_RESULT
>                   ERROR_VARIABLE    PULL_RESULT )
> file(WRITE ${PULL_RESULT_FILE} ${PULL_RESULT} )
Yep, remove those lines.
> OK. I changed the source and binary directories to:
> SET (CTEST_SOURCE_DIRECTORY "/Users/nsicadl/Dashboard/nightly/OTB-Release/src")
> SET (CTEST_BINARY_DIRECTORY "/Users/nsicad/Dashboard/nightly/OTB-Release/build")
> Do I need to create these directories (manually) before running the script?
CTEST_SOURCE_DIRECTORY is where you checked out the sources (or untar them), so it must exists.
CTEST_BINARY_DIRECTORY : i don't remember, just try
> I would like to change this line (below) to something else - not "OTB-macport"?
> CMAKE_INSTALL_PREFIX:STRING=$ENV{HOME}/Dashboard/nightly/OTB-Release/install/OTB-macport
> Can I do this like this?,
Of course, put anything you like there.
> CMAKE_INSTALL_PREFIX:STRING=$ENV{HOME}/Dashboard/nightly/OTB-Release/install/OTB-mtn_lion
> Would this be fine?
Yes
