[Qgis-developer] Sextante - OTB plugin and SAR data in Mac OS X
Noli Sicad nsicad at gmail.com
Mon Aug 27 21:30:07 PDT 2012
Hi Julien,
Disregard my last question, my last posting. I got confuse with the
"macport" reference in the script.
I read the script again and I got it now, almost.
I see I don't need to hg clone manually since it will be pulling the
nightly build
execute_process( COMMAND ${CTEST_HG_COMMAND} pull
http://hg.orfeo-toolbox.org/OTB-Nightly
                 WORKING_DIRECTORY "${CTEST_SOURCE_DIRECTORY}"
                 OUTPUT_VARIABLE   PULL_RESULT
                 ERROR_VARIABLE    PULL_RESULT )
file(WRITE ${PULL_RESULT_FILE} ${PULL_RESULT} )
OK. I changed the source and binary directories to:
SET (CTEST_SOURCE_DIRECTORY "/Users/nsicadl/Dashboard/nightly/OTB-Release/src")
SET (CTEST_BINARY_DIRECTORY "/Users/nsicad/Dashboard/nightly/OTB-Release/build")
Do I need to create these directories (manually) before running the script?
I would like to change this line (below) to something else - not "OTB-macport"?
CMAKE_INSTALL_PREFIX:STRING=$ENV{HOME}/Dashboard/nightly/OTB-Release/install/OTB-macport
Can I do this like this?,
CMAKE_INSTALL_PREFIX:STRING=$ENV{HOME}/Dashboard/nightly/OTB-Release/install/OTB-mtn_lion
Would this be fine?
Thanks.
Noli
On 8/28/12, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Julien,
> As you can see I am not using MacPort. MacPort download the source in
> the script that you mentioned in your previous posting?
> http://www.orfeo-toolbox.org/otb/download.html
> Based on the instruction above. It is not clear what to do with hg
> cloning in Mac OS X.
> Yes, I can do (below) in the terminal.
> hg clone http://hg.orfeo-toolbox.org/OTB
> Would this suffice, or I need to more?
> What do, I do next, do I need to clone OTB-Applications and
> OTB-Qgis-plugin?
>     OTB-Applications
> The current development version is available from the OTB-Applications
> mercurial repository at: http://hg.orfeo-toolbox.org/OTB-Applications
>     OTB-Qgis-plugins
> The current development version is available from the OTB-Qgis-plugins
> mercurial repository at: http://hg.orfeo-toolbox.org/OTB-Qgis-plugins
> Noli
