[Qgis-developer] Sextante - OTB plugin and SAR data in Mac OS X
William Kyngesburye
woklist at kyngchaos.com
Tue Aug 28 06:45:38 PDT 2012
On Aug 28, 2012, at 3:47 AM, Julien Malik wrote:
> Hi William,
> Le 28/08/2012 04:35, William Kyngesburye a écrit :
>> Noli,
>> I started looking at this to see what needs to be done to use my frameworks.
>> First, FLTK.
> To compile on 10.8, you will need a recent FLTK 1.3 checkout.
> The current MacPort version (r9650) compiles fine on 10.8, but not the official release.
Yes, dev 1.3.x source.
> Also note that compiling the OTB-FLTK bridge is not necessary for using OTB from QGis.
> So OTB_USE_VISU_GUI=OFF is fine when configuring OTB.
Hm, I wondered about that. Greatly simplifies otb for QGIS.
>> You need the dev 1.3.x source, for updates to support the new libpng in my UnixImageIO framework. You also need my FreeType framework (not part of the QGIS requirements).
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
