[Qgis-developer] Sextante - OTB plugin and SAR data in Mac OS X
William Kyngesburye
woklist at kyngchaos.com
Wed Aug 29 06:50:19 PDT 2012
On Aug 29, 2012, at 4:34 AM, Julien Malik wrote:
> Hi,
> Le 29/08/2012 11:22, Noli Sicad a écrit :
>> Hi Julien,
>> Yes, I will do these things that you mentioned below.
>> Meanwhile, I just test William's script with some addtion for the GDAL.
>> Here is part of the logs.
>> Nolis-MacBook-Pro:build nsicad$ cmake -D
>> CMAKE_INSTALL_PREFIX=/usr/local -D CMAKE_BUILD_TYPE=MinSizeRel -D
>> CMAKE_OSX_ARCHITECTURES="x86_64" -D CMAKE_OSX_DEPLOYMENT_TARGET="10.8"
>> -D CMAKE_OSX_SYSROOT="/Developer/SDKs/MacOSX10.8.sdk" -D
>> OTB_WRAP_QT=OFF -D OTB_WRAP_JAVA=OFF -D OTB_WRAP_PYTHON=OFF -D
>> BUILD_APPLICATIONS=ON -D OTB_USE_VISU_GUI=OFF -D
>> GDALCONFIG_EXECUTABLE:FILEPATH=/Library/Frameworks/GDAL.framework/unix/bin/gdal-config
>> -D GDAL_CONFIG:FILEPATH=/Library/Frameworks/GDAL.framework/unix/bin/gdal-config
>> -D GDAL_INCLUDE_DIR:STRING=/Library/Frameworks/GDAL.framework/unix/include
>> -D GDAL_LIBRARY:FILEPATH=/Library/Frameworks/GDAL.framework/unix//lib/libgdal.dylib
>> -D TIFF_LIBRARY=/Library/Frameworks/UnixImageIO.framework -D
>> GEOTIFF_LIBRARY=/Library/Frameworks/UnixImageIO.framework -D
>> JPEG_LIBRARY=/Library/Frameworks/UnixImageIO.framework -D
>> USE_OPENMP=OFF -D CMAKE_INSTALL_NAME_DIR=/usr/local/lib/otb ..
>> -- Repository status :
>> -- Mercurial version is 2.3
>> -- Repository revision is 0bbc4e4c5374
>> -- No files modified locally
>> -- Importing GDAL...
>> -- Found GDAL: /Library/Frameworks/GDAL.framework/unix/lib/libgdal.dylib
>> -- GDAL includes : /Library/Frameworks/GDAL.framework/unix/include
>> -- GDAL library : /Library/Frameworks/GDAL.framework/unix/lib/libgdal.dylib
>> -- GDAL version is 1.9.1
>> -- Testing if GDAL has tiff -- no
>> -- Testing if GDAL has geotiff -- no
>> -- Testing if GDAL has jpeg -- no
>> -- Testing if GDAL has OGR -- yes
>> -- Performing Test CHECK_GDALOPEN_SYMBOL
>> -- Performing Test CHECK_GDALOPEN_SYMBOL - Failed
>> CMake Warning at CMake/ImportGdal.cmake:210 (MESSAGE):
>> CHECK_GDALOPEN_SYMBOL test failed : your platform exhibits a gdal/geotiff
>> conflict.
> This is a test which fails on some linux distros (ubuntu/debian).
> I've never seen it fail on a Mac.
> And as William's framework is built with external geotiff, this should not fail.
> Might be a missing DYLD_LIBRARY_PATH (the test actually runs an executable during configuration).
It may be the gdal-config path creating confusion. There are actually 2 version of gdal-config in my framework. The one you used that is in the unix/ folder is designed for old software that doesn't handle framework flags - it uses the standard -Lpath -llib form. Maybe the test for the GDAL functions is seeing the Macports GDAL first, which causes a confusion of GDAL and tiff/geotiff libs.
The gdal-config in the Programs folder is what you want - it uses -framework linking, so you don't accidentally get a non-frameword GDAL. Same goes for manually specifying the GDAL lib and include paths. So:
-D GDAL_CONFIG=/Library/Frameworks/GDAL.framework/Programs/gdal-config
-D GDAL_INCLUDE_DIR=/Library/Frameworks/GDAL.framework/Headers
-D GDAL_LIBRARY=/Library/Frameworks/GDAL.framework
(cmake knows that a .framework for a library is a framework, and how to translate that for compilation)
> Anyway, proceed further with the compilation.
> It should be ok, this is just a warning.
>> William, what is it the GDAL have this nos
>> e.g.
> This is OK.
> It means gdal does not exposes tiff and geotiff symbols.
> This does not mean gdal does not have the tiff/jpeg driver.
> Julien
> Qgis-developer mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
- the wisdom of Tarzan
