[Qgis-developer] Sextante - OTB plugin and SAR data in Mac OS X
    Noli Sicad
    nsicad at gmail.com
    Wed Aug 29 19:18:34 PDT 2012
Hi William and Julien,
This one does not work.
 -D GDAL_CONFIG=/Library/Frameworks/GDAL.framework/Programs/gdal-config
See this log.
Nolis-MacBook-Pro:build nsicad$ cmake -D
CMAKE_INSTALL_PREFIX=/usr/local -D CMAKE_BUILD_TYPE=MinSizeRel -D
CMAKE_OSX_ARCHITECTURES="x86_64" -D CMAKE_OSX_DEPLOYMENT_TARGET="10.8"
-D CMAKE_OSX_SYSROOT="/Developer/SDKs/MacOSX10.8.sdk" -D
OTB_WRAP_QT=OFF -D OTB_WRAP_JAVA=OFF -D OTB_WRAP_PYTHON=OFF -D
BUILD_APPLICATIONS=ON -D OTB_USE_VISU_GUI=OFF -D
GDAL_CONFIG=/Library/Frameworks/GDAL.framework/Programs/gdal-config -D
GDAL_INCLUDE_DIR=/Library/Frameworks/GDAL.framework/Headers -D
GDAL_LIBRARY=/Library/Frameworks/GDAL.framework -D
TIFF_LIBRARY=/Library/Frameworks/UnixImageIO.framework -D
GEOTIFF_LIBRARY=/Library/Frameworks/UnixImageIO.framework -D
JPEG_LIBRARY=/Library/Frameworks/UnixImageIO.framework -D
USE_OPENMP=OFF -D CMAKE_INSTALL_NAME_DIR=/usr/local/lib/otb ..
-- Repository status :
--   Mercurial version is 2.3
--   Repository revision is 0bbc4e4c5374
--   No files modified locally
-- Importing GDAL...
--   GDAL includes : /Library/Frameworks/GDAL.framework/Headers
--   GDAL library  : /Library/Frameworks/GDAL.framework
CMake Error at CMake/ImportGdal.cmake:37 (MESSAGE):
  gdal-config not found or set to a wrong path.  Please check
  GDALCONFIG_EXECUTABLE
Call Stack (most recent call first):
  CMakeLists.txt:212 (INCLUDE)
However, this one works with still no support.
-D GDALCONFIG_EXECUTABLE:FILEPATH=/Library/Frameworks/GDAL.framework/Programs/gdal-config
See this logs.
-D GDAL_INCLUDE_DIR=/Library/Frameworks/GDAL.framework/Headers -D
--   GDAL version is 1.9.1
--   Testing if GDAL has tiff    -- no
--   Testing if GDAL has geotiff -- no
--   Testing if GDAL has jpeg    -- no
--   Testing if GDAL has OGR     -- yes
-- Importing LibLAS...
-- Could NOT find LIBLAS (missing:  LIBLAS_LIBRARY LIBLAS_INCLUDE_DIR)
-- Using LibLAS internal version
-- Importing EXPAT...
-- Using EXPAT external version
-- Importing ITK...
--   Using ITK internal version
-- Importing Jpeg2000...
--   Enabling Jpeg2000 support
-- Importing FLTK...
--   Disabling FLTK support
-- Importing Curl...
-- Using CURL external version
Anyway, I just make and make install.
I wonder how important is support for Tiff, GeoTiff, JPEG in GDAL affects OTB.
Yes, I managed to compile and install ITK, It takes hours to compile
and install it in Mac OS X.
Now, the Sextante OTB QGIS python plugin. It is not present in
Sextante, where can I download the QGIS python OTB plugin?
Julien, you have the address of the repository for this plugin?
There is no OTB instruction in Sextante Help that comes with Sextante
plugin. It is not written yet.
I am using Sextante 1.0.7.
Thanks.
Noli
> It may be the gdal-config path creating confusion.  There are actually 2
> version of gdal-config in my framework.  The one you used that is in the
> unix/ folder is designed for old software that doesn't handle framework
> flags - it uses the standard -Lpath -llib form.  Maybe the test for the GDAL
> functions is seeing the Macports GDAL first, which causes a confusion of
> GDAL and tiff/geotiff libs.
> The gdal-config in the Programs folder is what you want - it uses -framework
> linking, so you don't accidentally get a non-frameword GDAL.  Same goes for
> manually specifying the GDAL lib and include paths. So:
> -D GDAL_LIBRARY=/Library/Frameworks/GDAL.framework
> (cmake knows that a .framework for a library is a framework, and how to
> translate that for compilation)
