[Qgis-developer] Sextante - OTB plugin and SAR data in Mac OS X
William Kyngesburye
woklist at kyngchaos.com
Wed Aug 29 19:41:52 PDT 2012
On Aug 29, 2012, at 9:18 PM, Noli Sicad wrote:
> Hi William and Julien,
> This one does not work.
> -D GDAL_CONFIG=/Library/Frameworks/GDAL.framework/Programs/gdal-config
I guess GDAL_CONFIG is the wrong option
> However, this one works with still no support.
> -D GDALCONFIG_EXECUTABLE:FILEPATH=/Library/Frameworks/GDAL.framework/Programs/gdal-config
and GDALCONFIG_EXECUTABLE is the correct one.
> See this logs.
> -- Importing GDAL...
> -- GDAL includes : /Library/Frameworks/GDAL.framework/Headers
> -- GDAL library : /Library/Frameworks/GDAL.framework
> -- GDAL version is 1.9.1
> -- Testing if GDAL has tiff -- no
> -- Testing if GDAL has geotiff -- no
> -- Testing if GDAL has jpeg -- no
> -- Testing if GDAL has OGR -- yes
> Anyway, I just make and make install.
> I wonder how important is support for Tiff, GeoTiff, JPEG in GDAL affects OTB.
As Julien mentioned, this is just testing whether GDAL has TIFF/GeoTIFF/JPEG *libraries* built into it and exposed as libraries. It does not mean GDAL does not support these formats. I don't think you can build GDAL without these formats in the first place.
> Yes, I managed to compile and install ITK, It takes hours to compile
> and install it in Mac OS X.
No need to do that - OTB has an internal copy, see your cmake log:
> -- Importing ITK...
> -- Using ITK internal version
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
The equator is so long, it could encircle the earth completely once.
