[Qgis-developer] Sextante - OTB plugin and SAR data in Mac OS X
Noli Sicad
nsicad at gmail.com
Wed Aug 29 23:55:19 PDT 2012
Hi Julien,
I am almost at the end of this struggle :-).
On 8/27/12, Julien Malik <julien.malik at c-s.fr> wrote:
> Go to your build dir and type "make install"
Yes, I did the above.
I got a lot of otbcli_* in the /usr/local/bin
> Then look in CMAKE_INSTALL_PREFIX/bin and you should be able to launch
> an OTB application (otbcli_Something scripts)
Do I need to run some of these binaries to get the SEXTANTE OTB Plugin working.
I see the sextante/otb is present.
> Then in Sextante configuration, you should set :
> -"OTB command line tools" option to CMAKE_INSTALL_PREFIX/bin
> -"OTB applications folder" option to CMAKE_INSTALL_PREFIX/lib/otb
What file (python file?), I am looking to see these parameters?
It seem that my /sextante/otb/__init__.py is empty.
I got these files:
OTBAlgorithm.py
OTBAlgorithmProvider.py
OTBUtils.py
Thanks.
Noli
