[Qgis-developer] Sextante - OTB plugin and SAR data in Mac OS X
Julien Malik julien.malik at c-s.fr
Thu Aug 30 01:09:26 PDT 2012
Hi again,
Le 30/08/2012 08:55, Noli Sicad a écrit :
> Do I need to run some of these binaries to get the SEXTANTE OTB Plugin working.
Yes that is what Sextante/OTB uses.
Better check first that you have installed everything properly, and can
actually process some images with it.
>> Then in Sextante configuration, you should set :
>> -"OTB command line tools" option to CMAKE_INSTALL_PREFIX/bin
>> -"OTB applications folder" option to CMAKE_INSTALL_PREFIX/lib/otb
> What file (python file?), I am looking to see these parameters?
No, in the menu Analysis->Sextante option and configuration
Julien
