[Qgis-developer] Sextante - OTB plugin and SAR data in Mac OS X
    Noli Sicad
    nsicad at gmail.com
    Thu Aug 30 01:17:53 PDT 2012
Hi Julian,
> Le 30/08/2012 08:55, Noli Sicad a écrit :
>> Do I need to run some of these binaries to get the SEXTANTE OTB Plugin
>> working.
> Yes that is what Sextante/OTB uses.
> Better check first that you have installed everything properly, and can
> actually process some images with it.
>>> Then in Sextante configuration, you should set :
>>> -"OTB command line tools" option to CMAKE_INSTALL_PREFIX/bin
>>> -"OTB applications folder" option to CMAKE_INSTALL_PREFIX/lib/otb
>> What file (python file?), I am looking to see these parameters?
> No, in the menu Analysis->Sextante option and configuration
OK.
YES. I got it now.
It seems everything is working now.
Thanks a lot your help.
Regards,
Noli
