[Qgis-developer] OGR2Layers Plugin - Output textbox directory is not active in QGIS 1.8 Mac OS X
Noli Sicad
nsicad at gmail.com
Thu Aug 30 17:22:35 PDT 2012
I got problem in OGR2Layers Plugin, the Output textbox (i.e. output
directory) is not active in QGIS 1.8 Mac OS X.
It means that I can not input the directory for the output file, do
you know how to solve this problem?
It does not accept the default directory for the output as well.
"GDAL Active Layers" is also disabled.
Has anybody encountered the problem in QGIS 1.8 in other platforms?
How do you fix this issue?
Thanks.
Noli
