[Qgis-developer] OGR2Layers Plugin - Output textbox directory is not active in QGIS 1.8 Mac OS X
Luca Delucchi lucadeluge at gmail.com
Thu Aug 30 23:54:56 PDT 2012
2012/8/31 Noli Sicad <nsicad at gmail.com>:
> Hi,
Hi
> I got problem in OGR2Layers Plugin, the Output textbox (i.e. output
> directory) is not active in QGIS 1.8 Mac OS X.
> It means that I can not input the directory for the output file, do
> you know how to solve this problem?
I have no problem on linux (debian and ubuntu)
> It does not accept the default directory for the output as well.
what do you mean? what is default directory?
When you click on browser do you see a dialog for chose the output folder?
> "GDAL Active Layers" is also disabled.
Yes, I know it will be a future feature...
> Has anybody encountered the problem in QGIS 1.8 in other platforms?
I have no problem
> How do you fix this issue?
First we should be able to replicate the error :-)
> Thanks.
> Noli
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
