[Qgis-developer] OGR2Layers Plugin - Output textbox directory is not active in QGIS 1.8 Mac OS X
Noli Sicad
nsicad at gmail.com
Fri Aug 31 00:19:43 PDT 2012
Hi Luca,
The plugin try to write in /Applications folder in Mac OS X.
It manage to write the geojson files but not the index.html file. I
just find the geojson files there now.
Yes, I replicated this error in Mac OS X, I tried 3 files. The same
happened, trying to write in Applications folder when I am trying to
exit (close the plugin windows).
/Applications folder is system privilege only, sudo user only in Mac
OS X. It reserve for Applications only, not document or data.
It seems that the contour plugin is also doing the same. The output
directory is also disabled since it is trying to write in
/Applications folder which read only.
MMQGIS plugin shows the default directory as /Application folder when
I am trying to export the attribute table of shapefile.
Any Mac OS users try to replicate this error?
Thanks.
Noli
On 8/31/12, Luca Delucchi <lucadeluge at gmail.com> wrote:
> 2012/8/31 Noli Sicad <nsicad at gmail.com>:
>> Hi,
> Hi
>> I got problem in OGR2Layers Plugin, the Output textbox (i.e. output
>> directory) is not active in QGIS 1.8 Mac OS X.
>> It means that I can not input the directory for the output file, do
>> you know how to solve this problem?
> I have no problem on linux (debian and ubuntu)
>> It does not accept the default directory for the output as well.
> what do you mean? what is default directory?
> When you click on browser do you see a dialog for chose the output folder?
>> "GDAL Active Layers" is also disabled.
> Yes, I know it will be a future feature...
>> Has anybody encountered the problem in QGIS 1.8 in other platforms?
> I have no problem
>> How do you fix this issue?
> First we should be able to replicate the error :-)
>> Thanks.
>> Noli
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
