[Qgis-developer] OGR2Layers Plugin - Output textbox directory is not active in QGIS 1.8 Mac OS X
Noli Sicad nsicad at gmail.com
Fri Aug 31 05:29:38 PDT 2012
On 8/31/12, Etienne Tourigny <etourigny.dev at gmail.com> wrote:
> This might be a theme issue - which one are you using?
I am using classic.
I checked changing the theme into GIS, still the same problem. The
directory textbox and browse button are hidden. It need to lenghten
the height of the window pane to show directory textbox and browse
button.
Noli
