[Qgis-developer] OGR2Layers Plugin - Output textbox directory is not active in QGIS 1.8 Mac OS X
    Etienne Tourigny
    etourigny.dev at gmail.com
    Fri Aug 31 05:14:11 PDT 2012
This might be a theme issue - which one are you using?
Etienne
On Fri, Aug 31, 2012 at 6:22 AM, Noli Sicad <nsicad at gmail.com> wrote:
> Hi Luca,
>> Do you see the "Browse" button to chose the directory where export the
>> two files?
>> I try on colleague Mac and it works, the problem is only on the GUI
>> that hide the "browse" button, I only resize the windows and I could
>> set the directory.
>> See the two images before resize [0] and after [1]
>> For me the problem is fixed I should only resize the GUI
> OK. This is the problem because I did not resize the window.
> Yes, It is hidden.
> Now, when I resize the windows, the browse button and the directory
> textbox are visible now.
> I  thought before that the small pane before the "Close" and "OK"
> buttons is the directory textbox for use to entry the directory. I am
> mistaken.
> Resizing the window panel make the directory textbox and browse button!
> Luca, thanks a lot for attention on this small glitch of not viewing
> the directory textbox and button.
> It would probably better to resize the default size of the window pane
> so by default we can see the directory textbox and browse button.
> Thanks again.
> Regards,
> Noli
> Qgis-developer mailing list
