[Qgis-developer] WPS server
    rldhont
    rldhont at gmail.com
    Mon Dec  3 05:31:37 PST 2012
Le 03/12/2012 14:05, Martin Dobias a écrit :
> Hi Rene-Luc
> On Mon, Dec 3, 2012 at 10:01 AM, rldhont <rldhont at gmail.com
> <mailto:rldhont at gmail.com>> wrote:
>     With the QGIS Expression you just have to know how to write an
>     expression to create a new Process. It's not coding.
>     For example the Buffer Process can be described like this :
>     buffer("geometry","distance")
>     You want to create a Process which retrun the buffer without the
>     geometry :
>     difference(buffer("geometry","distance"),"geometry")
>     And we can define a Process which return the result of a QGIS
>     Expression as the Process parameter.
> Thanks for sharing your thoughts about your implementation.
> I would like to express my concerns that using QgsExpression may be a
> dead end for a generic WPS servers. Expressions are meant to deal with
> individual features of a vector layer. You're right that it's possible
> to define your own functions and chain them to create processes, but
> this is very limited. For example it's not possible for a process to
> return more results and it's not possible to use one result more than
> once. Just like raster calculator has its own expression engine, also
> the processing service should use a way of describing algorithms that
> suits best its needs - and in our case that's python+SEXTANTE.
> Therefore I strongly recommend using SEXTANTE for the WPS server
> backend. I believe that would be less work than trying to hack
> QgsExpression to use it for processing. You would just need to parse
> WPS query, generate a Python script that would run SEXTANTE analysis
> and then create WPS reply. It's probably not desirable to run the
> processing directly within the server process (thread), so this would
> be a better solution either way.
Hi Martin,
My idea was to have a simple WPS server based on QGIS-Server, very
simple for simple vector case, and I thought it's a good idea. I only
need to validate geometry, constructing simple buffer or intersection.
For big processing, I think SEXTANTE is better suitable, but for a WPS
serveur, SEXTANTE didn't need QGIS. We can construct a WPS Server based
on pySextante with pyWPS.
I don't really want to hack QgsExpression, just accesses to very simple
processing, I'll just it. For SEXTANTE, It will be better to work on
someting based on pyWPS.
René-Luc
> Regards
> Martin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121203/fc9c9459/attachment.html>
