[Qgis-developer] Where are the points?
Ian Packham i.packham at ucd.ie
Wed Dec 5 10:35:32 PST 2012
Justin
Which version of QGIS are you using? Are you using code exactly as in the cookbook (Using Vector Layers chapter?)?. If not, can you provide the code? Also how did you create the symbology?
Ian
----- Original Message -----
From: Justin Hubbard <justin at pyrotechsoftware.com>
Date: Wednesday, December 5, 2012 1:51 pm
Subject: [Qgis-developer] Where are the points?
To: qgis-developer <qgis-developer at lists.osgeo.org>
> In my plugin, I am able to create features as per the cookbook. And when I zoom to the layer extent I can see the points are there and they are rendered as per my symbology.
> However when I try to zoom / Pan to them, they disappear. > If I run QgsFeature.isValid() they all return true. I just cannot understand it.
> Warm regards
> Justin Hubbard
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121205/17b0ef9f/attachment.html>
