[Qgis-developer] Where are the points?
Justin Hubbard justin at pyrotechsoftware.com
Thu Dec 6 05:12:39 PST 2012
Hi.
When I load the layer outside of the plugin I get the same problem.
If there is a problem with the database indexes, how would I rectify this?
On Thu, Dec 6, 2012 at 10:36 AM, Pēteris Brūns <pb at sungis.lv> wrote:
>  Hi,
> try to open your Spatialite db and add layer without plugin. If then also
> are missing some geometries can be problems with your Spatialite database
> indexes.
> Regards,
> On 2012.12.06. 10:22, Tim Sutton wrote:
> Hi
> On Thu, Dec 6, 2012 at 8:47 AM, Justin Hubbard <
> justin at pyrotechsoftware.com> wrote:
>> Hi
>>  I am using QGis 1.8.
>>  The code I am using is identical to the code in the cookbook. I have
>> also tried doing this in the console. Same result.
>> When I create a new shapefile layer and add the points as described in
>> the code, they appear correctly.
>> However with this layer - Which is a Spatialite Layer I cannot see the
>> points at all.
>>  With regards to the symbology, I have tried new and old symbology, and
>> even loading the layer in a blank project with no custom symbology at all.
>> Same result.
>> If I use the map tool to create a point with the mouse the point appears,
>> and works correctly. This is causing me to think that the error is in the
>> code. (Perhaps Spatialite requires something extra?)
>  Justin it is always better to provide code samples (as plain text)  - it
> makes it much easier to help you as we can see exactly what you are
> doing....
>  Did you commit your changes to the dataset?
>  Regards
>  Tim
>> On Wed, Dec 5, 2012 at 8:35 PM, Ian Packham <i.packham at ucd.ie> wrote:
>>> Justin
>>> Which version of QGIS are you using? Are you using code exactly as in
>>> the cookbook (Using Vector Layers chapter?)?. If not, can you provide the
>>> code? Also how did you create the symbology?
>>> Ian
>>> ----- Original Message -----
>>> From: Justin Hubbard <justin at pyrotechsoftware.com>
>>> Date: Wednesday, December 5, 2012 1:51 pm
>>> Subject: [Qgis-developer] Where are the points?
>>> To: qgis-developer <qgis-developer at lists.osgeo.org>
>>> > In my plugin, I am able to create features as per the cookbook. And
>>> when I zoom to the layer extent I can see the points are there and they are
>>> rendered as per my symbology.
>>>  > However when I try to zoom / Pan to them, they disappear.
>>> > If I run QgsFeature.isValid() they all return true. I just cannot
>>> understand it.
>>> > Warm regards
>>> *> Justin Hubbard*
>> Warm regards
>> *Justin Hubbard*
>> *Justin Hubbard*
>> Software Engineer and Support
>>   Mobile:
>>   +27 (0)79 827 1657 <%2B27%20%280%2979%20827%201657>
>>   Fax:
>>   +27 (0)86 540 6016 <%2B27%20%280%2986%20540%206016>
>>   Email:
>>   justin at pyrotechsoftware.com <robert at plannermunicipalsoftware.co.za>
>>   Web Site:
>>   www.pyrotechsoftware.co <http://www.plannermunicipalsoftware.co.za/>m
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
>  * QGIS programming and support services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
> Qgis-developer mailing listQgis-developer at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-developer
> Pēteris
Warm regards
*Justin Hubbard*
*Justin Hubbard*
  Mobile:
  +27 (0)79 827 1657
  Fax:
  +27 (0)86 540 6016
  Email:
  Web Site:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121206/65df6b0a/attachment-0001.html>
