[Qgis-developer] New FAKE_LIB_GRASS_GIS fails to compile on Mac OS X
John C. Tull
jctull at gmail.com
Mon Dec 10 12:07:32 PST 2012
On Dec 10, 2012, at 11:59 AM, Radim Blazek <radim.blazek at gmail.com> wrote:
> On Mon, Dec 10, 2012 at 8:43 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
>> On Mon, Dec 10, 2012 at 12:14 PM, John C. Tull <jctull at gmail.com> wrote:
>>> On Dec 8, 2012, at 11:03 AM, Radim Blazek <radim.blazek at gmail.com> wrote:
>>> The output should be standard shared library. I have probably copy-pasted
>>> wrong (provider) block. I have no idea what is the difference on OS X.
>>> Sorry for the problems, i dont have access to source code at this moment,
>>> could you try to change
>>> CMakeLists.txt to build simple shared library.
>>> Radim
>>> On Dec 8, 2012 6:25 PM, "Larry Shaffer" <larrys at dakotacarto.com> wrote:
>>>> Hi,
>>>> With recent commit:
>>>> https://github.com/qgis/Quantum-GIS/commit/4dc84995ee4dec8fe4b927a650b900e7edddaad4
>>>> Build of FAKE_LIB_GRASS_GIS fails on Mac OS X with:
>>>> Linking CXX shared module ../../../PlugIns/qgis/libgrass_gis.6.4.2.so
>>>> clang: error: invalid argument '-compatibility_version 1.9.0' only
>>>> allowed with '-dynamiclib'
>>>> make[2]: *** [PlugIns/qgis/libgrass_gis.6.4.2.1.9.0.so] Error 1
>>>> make[1]: *** [src/providers/grass/CMakeFiles/grass_gis.6.4.2.dir/all]
>>>> Error 2
>>>> In src/providers/grass/CMakeLists.txt it seems a MODULE, and not
>>>> SHARED library is generated (which I think is needed if a framework is
>>>> being built), but I do not know enough about this aspect of CMake, or
>>>> the build process, to fix it.
>>>> Any help would be appreciated.
>>>> Regards,
>>>> Larry
>>> Did anyone come up with a workaround for this? I am still getting the error
>>> on my build attempts for trunk:
>> Hi John,
>> I have a new pull request in for fixing this on Mac, but am not
>> entirely sure I did it correctly (or what the new FAKE_LIB_GRASS_GIS
>> does or how to test it):
>> https://github.com/qgis/Quantum-GIS/pull/349
>> https://github.com/qgis/Quantum-GIS/pull/349.patch
> Thanks Larry,
> I have pushed that to the master. The library should make it possible
> to run GRASS modules without mapset and data data import. You can try
> to run a GRASS module in this mode from GRASS Tools ( which is now
> always enabled), if no mapset is open. Most probably it will need more
> fixes on Mac and Win. It is work in progress, currently there are only
> few modules and you can find problems.
> I'll write more about in another thread soon.
> Radim
Hi Radim,
I just tested one of the available modules on a local DEM file, and here is there error message that appeared when I ran it:
Cannot start module r.slope.aspect
command: /usr/local/Cellar/grass/6.4.2/grass-6.4.2/bin/r.slope.aspect --interface-description
ERROR: GISRC - variable not set
Note that I am running a version of grass installed locally, not from the application that William makes available.
Regards,
John
