[Qgis-developer] New FAKE_LIB_GRASS_GIS fails to compile on Mac OS X
Radim Blazek radim.blazek at gmail.com
Mon Dec 10 13:22:07 PST 2012
On Mon, Dec 10, 2012 at 9:07 PM, John C. Tull <jctull at gmail.com> wrote:
> Hi Radim,
> I just tested one of the available modules on a local DEM file, and here is there error message that appeared when I ran it:
>  Cannot start module r.slope.aspect
> command: /usr/local/Cellar/grass/6.4.2/grass-6.4.2/bin/r.slope.aspect --interface-description
> ERROR: GISRC - variable not set
> Note that I am running a version of grass installed locally, not from the application that William makes available.
If you get such error it means that the fake library was not found
(standard grass_gis library is complaining about missing environment).
The problem was that DYLD_LIBRARY_PATH was not set. Please try again
with master.
Radim
> Regards,
> John
