[Qgis-developer] Sextante add new algorithm to toolbox
Victor Olaya volayaf at gmail.com
Tue Dec 11 00:02:44 PST 2012
Anita
If you algorithm is of general interest and you don't mind sharing it,
we can put it in the SEXTANTE code and distribute it along with the
other ftools algorithms.
If you do not want to have it in the ftools group, then you can also
create you own algorithm provider in its own plugin (the example
provider plugin will show you how to do it, or you can ask us here),
and that will work just copying to the plugins folder, in case you
want to install it in a different machine.
Hope this helps
Victor
2012/12/11 Alexander Bruy <alexander.bruy at gmail.com>:
> Hi Anita,
> On Tue, 11 Dec 2012 08:38:40 +0100
> Anita Graser <anitagraser at gmx.at> wrote:
>> What do I have to do to make it show up in the toolbox?
> You need to expose your algorithm is provider. Open file FToolsAlgorithmProvider.py, add import statement with your new alg
> (use existing statements as example) and then in __init__ method
> add your algorithm to algorithms list — variable self.alglist.
> Hope this helps
> Alexander Bruy
> Qgis-developer mailing list
