[Qgis-developer] Sextante add new algorithm to toolbox
Werner Macho werner.macho at gmail.com
Tue Dec 11 00:33:41 PST 2012
Hi!
Would it make sense to integrate the "new" algorithm as a selectable option
into the "old" algorithm?
regards
Werner
On Tue, Dec 11, 2012 at 9:27 AM, Anita Graser <anitagraser at gmx.at> wrote:
> > 2012/12/11 Alexander Bruy <alexander.bruy at gmail.com>:
> >> You need to expose your algorithm is provider. Open file
> FToolsAlgorithmProvider.py, add import statement with your new alg
> >> (use existing statements as example) and then in __init__ method
> >> add your algorithm to algorithms list — variable self.alglist.
> Thanks Alexander! That worked perfectly.
> On Tue, Dec 11, 2012 at 9:02 AM, Victor Olaya <volayaf at gmail.com> wrote:
> > If you algorithm is of general interest and you don't mind sharing it,
> > we can put it in the SEXTANTE code and distribute it along with the
> > other ftools algorithms.
> It's a very simple modification. Instead of providing the algorithm
> with a fixed number of points to insert into the geometry, I made it
> calculate how many points it needs to put one at every interval step.
> I'll test some more and send it to you later if you don't mind. Or
> should I go the Github way?
> Best wishes,
> Anita
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20121211/f67a0fdd/attachment.html>
