[Qgis-developer] Legend group API
Sandro Santilli
strk at keybit.net
Tue Dec 11 08:25:57 PST 2012
On Tue, Dec 11, 2012 at 07:42:08AM -0800, Massimo Endrighi wrote:
> Sandro Santilli-2 wrote
> > I think Martin ideas is sensible and I do see the code is going
> > in that direction. But even if the classes are decoupled from
> > the QT tree widget we'll need a way to identify groups, as much
> > as we do with layers (which do have an ID). I've no problem with
> > all elements (be them layers or groups or whatever) share the
> > same "id space" but each one should have an identifier which
> > remains valid for the whole lifetime of that object.
> Please keep in mind that it is also necessary to be able to:
> - move/put a layer into a sub group (not only a top level item as it was in
> 1.8)
> - remove a sub group (not only a top level item as it was in 1.8)
> - move a layer before or after another layer inside the same group
> - walk thought the legend hierarchy even when there are sub groups and
> multiple group with the same name (the groupLayerRelationship is unusable in
> some circumstances)
I'm a fan of incremental refactoring, to minimize regressions.
In this case I don't think the current API, nor the 1.8 one allowed
for moving a layer before or after another one inside or outside a group,
but in all APIs the so-called "groupIndex" seems to be effectively used
as an identifier fo the group:
//! Add a new group
//! @note added parentIndex parameter in 1.7
virtual int addGroup( QString name, bool expand, int parentIndex ) = 0;
//! Remove group on index
virtual void removeGroup( int groupIndex ) =0;
//! Move a layer to a group
virtual void moveLayer( QgsMapLayer * layer, int groupIndex ) =0;
There's even:
//! Check if a group exists
//! @note added in 1.5
virtual bool groupExists( int groupIndex ) =0;
All these functions take an "int" but all assume it identifies a group,
not a location in a tree.
I'm happy with the interface extending to allow more fine-tuned access to
the tree, but it must also be possile to effectively use the above functions
the way they are documented to work, and adding the concept of a
"group identifier" (basically replacing "groupIndex" with "groupID")
keeps the same interface just making it unambiguos.
Methods dealing with the tree I think should not contain the "Layer" or
"Group" names, but only "Tree" and "Element"...
--strk;
