[Qgis-developer] CSV Layers cannot be picked as input in Sextante
Anita Graser
anitagraser at gmx.at
Sat Dec 15 10:55:22 PST 2012
I just finished my join script for Sextante but it isn't as useful as
I would like it to be because I cannot pick CSV files (loaded using
Add Vector Layer) as input.
Can I fix this using a different input definition? Script follows.
On a related note: It's possible to select CSVs loaded using Add
Delimited Text layer. But the join will have only one result. It seems
like provider.nextFeature(inFeat) doesn't work properly in this case.
Best wishes,
Anita
#Definition of inputs and outputs
##[my scripts]=group
##input1=vector
##join_field1=field input1
##input2=vector
##join_field2=field input2
##output=output vector
#Algorithm body
from sextante.core.QGisLayers import QGisLayers
from qgis.core import *
from PyQt4.QtCore import *
from sextante.core.SextanteVectorWriter import SextanteVectorWriter
# Layer 1
layer = QGisLayers.getObjectFromUri(input1)
provider = layer.dataProvider()
allAttrs = provider.attributeIndexes()
provider.select( allAttrs )
join_field1_index = provider.fieldNameIndex(join_field1)
# Layer 2
layer2 = QGisLayers.getObjectFromUri(input2)
provider2 = layer2.dataProvider()
allAttrs = provider2.attributeIndexes()
provider2.select( allAttrs )
fields2 = provider2.fields()
join_field2_index = provider2.fieldNameIndex(join_field2)
# Output
outFields = provider.fields()
for (i,f) in fields2.iteritems():
f.setName("x_"+f.name())
outFields[len(outFields)] = f
writer = SextanteVectorWriter(output, None, outFields,
provider.geometryType(), provider.crs() )
inFeat = QgsFeature()
inFeat2 = QgsFeature()
outFeat = QgsFeature()
# Create output vector layer with additional attribute
while provider.nextFeature(inFeat):
inGeom = inFeat.geometry()
atMap = inFeat.attributeMap()
join_value1 = atMap[join_field1_index].toString()
while provider2.nextFeature(inFeat2):
inGeom2 = inFeat2.geometry()
atMap2 = inFeat2.attributeMap()
join_value2 = atMap2[join_field2_index].toString()
if join_value1 == join_value2:
# create the new feature
outFeat.setGeometry( inGeom )
outFeat.setAttributeMap( atMap )
l = len(provider.fields())
for (i,a) in atMap2.iteritems():
outFeat.addAttribute( l+i, a )
writer.addFeature( outFeat )
del writer
