[Qgis-developer] CSV Layers cannot be picked as input in Sextante
Anita Graser
anitagraser at gmx.at
Sun Dec 16 23:23:44 PST 2012
On Sat, Dec 15, 2012 at 11:53 PM, Victor Olaya <volayaf at gmail.com> wrote:
> You are not using the geometry of the second layer, so instead of a
> vector layer, you could define it as a table.
> You should replace "##input2=vector" with "#input2=table"
I'll give that a try. Thanks!
> However, you are not going to be able to select vector layers in this
> case, just independent csv and dbf files loaded into QGIS. I think I
> can solve that by changing the behaviour of SEXTANTE, and allowing it
> to consider any vector layer also as a table.
Is there any way to make Sextante accept CSVs with WKT geometry loaded
using OGR/Add Vector Layer? They currently don't show up in Layer
selectors.
Best wishes,
Anita
