[Qgis-developer] error running qgis master - sextante depends on psycopg2 - but this dependency isn't well known
Etienne Tourigny etourigny.dev at gmail.com
Wed Dec 19 13:08:43 PST 2012
Hi
I had this problem today with a fresh build (done manually) and
install on a new machine, using today's master.
I am running Linux Mint 14 (Nadia).
Couldn't load plugin 'sextante' from [...]
ImportError: No module named psycopg2
Installing python-psycopg2 fixed the issue.
This should probably be added as a dependency to qgis build process,
or documented, or perhaps even tested in sextante so it doesn't throw
the error?
Regards,
Etienne
