[Qgis-developer] error running qgis master - sextante depends on psycopg2 - but this dependency isn't well known
Victor Olaya
volayaf at gmail.com
Wed Dec 19 13:33:58 PST 2012
Sounds good to me.
I assumed that it would be installed, but it's a better idea to add it
explicitly
I will add a check to SEXTANTE, so in case it is not installed, it
leaves out the algorithms that use it
Thanks!
Victor
2012/12/19 Etienne Tourigny <etourigny.dev at gmail.com>:
> Hi
> I had this problem today with a fresh build (done manually) and
> install on a new machine, using today's master.
> I am running Linux Mint 14 (Nadia).
> Couldn't load plugin 'sextante' from [...]
> Traceback (most recent call last):
> ImportError: No module named psycopg2
> Installing python-psycopg2 fixed the issue.
> This should probably be added as a dependency to qgis build process,
> or documented, or perhaps even tested in sextante so it doesn't throw
> the error?
> Regards,
> Etienne
> Qgis-developer mailing list
