[Qgis-developer] error running qgis master - sextante depends on psycopg2 - but this dependency isn't well known
Etienne Tourigny etourigny.dev at gmail.com
Wed Dec 19 13:49:27 PST 2012
Ideally it could be a dependency to .deb files (or osgeo/whatever),
and the build notes could include that package.
In any case, perhaps a one-time error window with a QErrorMessage that
psycopg2 is needed for some algorithms.
Etienne
On Wed, Dec 19, 2012 at 7:33 PM, Victor Olaya <volayaf at gmail.com> wrote:
> Sounds good to me.
> I assumed that it would be installed, but it's a better idea to add it
> explicitly
> I will add a check to SEXTANTE, so in case it is not installed, it
> leaves out the algorithms that use it
> Thanks!
> Victor
> 2012/12/19 Etienne Tourigny <etourigny.dev at gmail.com>:
>> Hi
>> I had this problem today with a fresh build (done manually) and
>> install on a new machine, using today's master.
>> I am running Linux Mint 14 (Nadia).
>> Couldn't load plugin 'sextante' from [...]
>> Traceback (most recent call last):
>> ImportError: No module named psycopg2
>> Installing python-psycopg2 fixed the issue.
>> This should probably be added as a dependency to qgis build process,
>> or documented, or perhaps even tested in sextante so it doesn't throw
>> the error?
>> Regards,
>> Etienne
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
