[Qgis-developer] SAGA modules (version 2.1.0) through SEXTANTE on Mac OSX
    Olav Peeters
    opeeters at gmail.com
    Fri Dec 21 13:24:31 PST 2012
A quick and dirty circumvention of the check is to change line 373 in
~/.qgis/python/plugins/sextante/saga/SagaAlgorithm.py
to:
if "" in line:
(restart Qgis)
this way the modules do open since the check is basically disabled.
The original code should also though. Maybe it's encoding related.
When I execute a Saga module, this happens during saving the output:
An error has occured while executing Python code:
   File
"/Users/myaccount/.qgis//python/plugins/sextante/gui/OutputSelectionPanel.py",
line 95, in saveToFile
     self.text.setText(str(filename))
UnicodeEncodeError: 'ascii' codec can't encode character u'\xff' in
position 2: ordinal not in range(128)
Should I have compiled with a different locale set?
We are nearly there :-)
Olav
On 20/12/12 23:09, Victor Olaya wrote:
> There is actually the following check in the case of mac and linux:
>              command = ["saga_cmd"]
>              proc = subprocess.Popen(command, shell=True,
> stdout=subprocess.PIPE,
> stdin=subprocess.PIPE,stderr=subprocess.STDOUT,
> universal_newlines=True).stdout
>              for line in iter(proc.readline, ""):
>                  if "________" in line:
>                      settings.setValue(SAGA_INSTALLED, True)
>                      return
>              return "It seems that SAGA is not correctly installed in
> your system.\nPlease install it before running SAGA algorithms."
> basically, it is a naive check to see if executing saga_cmd in a
> console returns something that looks like the SAGA CMD header. It
> works fin in linux, but it seems it is not working in Mac. Are you
> sure saga is in your path? if so, what do you see when you execute
> saga_cmd? maybe the header is different for some reason?
> Thanks in advance!
> 2012/12/20 John C. Tull <jctull at gmail.com>:
>> On Dec 19, 2012, at 2:49 AM, Victor Olaya <volayaf at gmail.com> wrote:
>>> Olav,
>>> Thanks for your contribution!
>>>> There is no option "SAGA folder" in the SEXTANTE configuration like you have
>>>> when installing on Windows. I haven't checked on Linux, but I guess the
>>>> Unixes don't need this, as long as saga_cmd is in the path, right?
>>> Right, Mac and Linux should work in the same way. Let me check,
>>> because maybe in Mac it is performing the same check as in windows
>>> (that is, checking that the SAGA folder is set...)
>>> Looks like an easy to solve problem...i hope
>>> Will keep you posted
>>> Thanks again!
>>> Victor
>> It looks like I'm a little late to the party on this. I confirm the same. I look forward to a solution on this for OS X. We can work on grass, perhaps, once that is resolved.
>> Regards,
>> John
