[Qgis-developer] Composer redesign
Paolo Cavallini cavallini at faunalia.it
Thu Feb 2 08:14:13 EST 2012
Il 02/02/2012 14:06, Nathan Woodrow ha scritto:
> Hi all,
>     * Redesign the composition (general) tab to remove the need
>       to vertical scroll, in most cases. (Not a perfect redesign but
>       it works IMO much better then the old layout)
+1
>     * Remove wasted space around paper area and widget (see picture[1]
>       vs your install to see the difference)
+1
>     * Convert the split widget + tab widget to QDockWidgets. 1) The
>       splitter didn't remember its last position or state 2) Could
>       only view one tab at a time 3) The main QGIS window uses dock
>       widgets to allow flexibility in screen layout, composer should
>       too. 4) Can't hide tabs if you don't need to see them all the
>       time e.g. command history . Using dock widgets solves all of
>       these issues.
+1
Thanks a lot Nathan!
All the best.
Paolo Cavallini
See: http://www.faunalia.it/pc
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120202/03894384/attachment.html
