[Qgis-developer] dev stats
Nathan Woodrow
madmanwoo at gmail.com
Fri Feb 3 02:23:33 EST 2012
I was going to get a csv dump out redmine and generate something like this
at one stage (a simple version anyway).
The current problem is the the redmine export limit is too low so you can't
export all the issue out, only get about 500 when there a lot more.
There is a limit variable that you can increase, can we get that increased
to allow a bigger dump out?
Regards,
Nathan
On Fri, Feb 3, 2012 at 5:01 PM, Paolo Cavallini <cavallini at faunalia.it>wrote:
> Quite interesting:
> http://blog.**documentfoundation.org/2012/**02/02/fosdem-preview/<http://blog.documentfoundation.org/2012/02/02/fosdem-preview/>
> In ohloh we have something similar (but unfortunately we lost our history
> during the passage from svn to git), so would someone volunteer to set up a
> similar set of plots?
> All the best.
> Paolo Cavallini
> See: http://www.faunalia.it/pc
> ______________________________**_________________
> Qgis-developer mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120203/4d31a75c/attachment.html
